{An orderly linear PDE system with analytic initial conditions with a non analytic solution} - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2003
We give a linear PDE system, with analytic initial conditions given w.r.t an orderly ranking, the solution of which is not analytic (moreover the solution is not Gevrey for any order). This examples proves that the analyticity Riquier theorem (generalization of the Cauchy-Kovalevskaya theorem) does not generalize to PDE systems endowed with orderly rankings.
Fichier non déposé
hal-00545215 , version 1 (09-12-2010)
  • HAL Id : hal-00545215 , version 1
François Lemaire. {An orderly linear PDE system with analytic initial conditions with a non analytic solution}. Journal of Symbolic Computation, 2003, 35 (5), pp.487-498. ⟨hal-00545215⟩
65 Consultations
0 Téléchargements
