Atomic Cut Introduction by Resolution: Proof Structuring and Compression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The careful introduction of cut inferences can be used to structure and possibly compress formal sequent calculus proofs. This pa- per presents CIRes, an algorithm for the introduction of atomic cuts based on various modifications and improvements of the CERes method, which was originally devised for efficient cut-elimination. It is also demonstrated that CIRes is capable of compressing proofs, and the amount of compres- sion is shown to be exponential in the length of proofs.
AtomicCutIntroduction_-_Submitted_Version.pdf (136.23 Ko) Télécharger le fichier
hal-00545473 , version 1 (11-12-2010)
Bruno Woltzenlogel Paleo. Atomic Cut Introduction by Resolution: Proof Structuring and Compression. Logic for Programming, Artificial Intelligence, and Reasoning, Apr 2010, Dakar, Senegal. pp.463-480, ⟨10.1007/978-3-642-17511-4_26⟩. ⟨hal-00545473⟩
151 Consultations
147 Téléchargements
