Benchmarking a Weighted Negative Covariance Matrix Update on the BBOB-2010 Noiseless Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nikolaus Hansen
Raymond Ros
  • Fonction : Auteur
  • PersonId : 848281
We implement a weighted negative update of the covariance matrix in the CMA-ES—weighted active CMA-ES or, in short, aCMA-ES. We benchmark the IPOP-aCMA-ES and compare the performance with the IPOP-CMA-ES on the BBOB-2010 noiseless testbed in dimensions between 2 and 40. On nine out of 12 essentially unimodal functions, the aCMA is faster than CMA, in particular in larger dimen- sion. On at least three functions it also leads to a (slightly) better scaling with the dimension. In none of the 24 bench- mark functions aCMA appears to be significantly worse in any dimension. On two and five functions, IPOP-CMA- ES and IPOP-aCMA-ES respectively exceed the record ob- served during BBOB-2009.
ws1p32-hansen.pdf (1.21 Mo) Télécharger le fichier
hal-00545728 , version 1 (11-12-2010)
hal-00545728 , version 2 (13-12-2010)
Nikolaus Hansen, Raymond Ros. Benchmarking a Weighted Negative Covariance Matrix Update on the BBOB-2010 Noiseless Testbed. Genetic And Evolutionary Computation Conference, Jul 2010, Portland, United States. pp.1673-1680, ⟨10.1145/1830761.1830788⟩. ⟨hal-00545728v1⟩
519 Consultations
425 Téléchargements
