Higher-Order Discontinuous Galerkin Method for Pyramidal Elements using Orthogonal Basis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
We study arbitrarily high-order finite elements defined on pyramids on discontinuous Galerkin methods. We propose a new family of high-order pyramidal finite element using orthogonal basis functions which can be used in hybrid meshes including hexahedra, tetrahedra, wedges and pyramids. We perform a comparison between these orthogonal functions and nodal functions for affine and non-affine elements. Different strategies for the inversion of mass matrix are also considered and discussed. Numerical experiments are conducted for 3-D Maxwell's equations.
JCM-HybrideDG.pdf (1.16 Mo) Télécharger le fichier
hal-00547319 , version 1 (16-12-2010)
hal-00547319 , version 2 (13-12-2011)
  • HAL Id : hal-00547319 , version 1
Morgane Bergot, Marc Duruflé. Higher-Order Discontinuous Galerkin Method for Pyramidal Elements using Orthogonal Basis. 2010. ⟨hal-00547319v1⟩
Collections
ENSTA
348 Consultations
643 Téléchargements
