Linear stability analysis of reaction fronts propagation in liquids with vibrations
Influence of vibrations on the onset of convective instability of reaction fronts in a liquid medium is studied. The model consists of a reaction-diffusion system coupled with the Navier-Stokes equations under the Boussinesq approximation. Linear stability analysis of the problem is fulfilled, and the convective instability boundary is found.
