2D electrostatic problems with rounded corners - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
François Buret
Laurent Krähenbühl
Connectez-vous pour contacter l'auteur
Ronan Perrussel
Damien Voyer
  • Fonction : Auteur
  • PersonId : 841634
The second order terms of a multiscale expansion for dealing with rounded corners in 2D electrostatic problems are studied. The main ideas and the sequence of problems to consider are recalled and finite element simulations are presented to assess the accuracy of the method.
ElectroHighorder.pdf (105.76 Ko) Télécharger le fichier
hal-00549384 , version 1 (21-12-2010)
hal-00549384 , version 2 (30-03-2011)
  • HAL Id : hal-00549384 , version 1
François Buret, Monique Dauge, Patrick Dular, Laurent Krähenbühl, Victor Péron, et al.. 2D electrostatic problems with rounded corners. Compumag 2011, Jul 2011, Sydney, Australia. n°549 - à paraître. ⟨hal-00549384v1⟩
Collections
AMPERE
743 Consultations
242 Téléchargements
