Multi-operator Scaling Random Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Processes and their Applications Année : 2011
Hermine Biermé
  • Fonction : Auteur
  • PersonId : 946725
Céline Lacaux
In this paper, we define and study a new class of random fields called harmonizable multi-operator scaling stable random fields. These fields satisfy a local asymptotic operator scaling property which generalizes both the local asymptotic self-similarity property and the operator scaling property. Actually, they locally look like operator scaling random fields whose order is allowed to vary along the sample paths. We also give an upper bound of their modulus of continuity. Their pointwise Hölder exponents may also vary with the position x and their anisotropic behavior is driven by a matrix which may also depend on x.
MultiOSpreprint.pdf (370.37 Ko) Télécharger le fichier
hal-00551707 , version 1 (04-01-2011)
hal-00551707 , version 2 (03-10-2011)
  • HAL Id : hal-00551707 , version 1
Hermine Biermé, Céline Lacaux, Hans-Peter Scheffler. Multi-operator Scaling Random Fields. Stochastic Processes and their Applications, 2011, 121, pp.2642--2677. ⟨hal-00551707v1⟩
462 Consultations
334 Téléchargements
