Statistically Linearized Recursive Least Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthieu Geist
Olivier Pietquin
This article proposes a new interpretation of the sigmapoint kalman filter (SPKF) for parameter estimation as being a statistically linearized recursive least-squares algorithm. This gives new insight on the SPKF for parameter estimation and particularly this provides an alternative proof for a result of Van der Merwe. On the other hand, it legitimates the use of statistical linearization and suggests many ways to use it for parameter estimation, not necessarily in a least-squares sens.
Fichier non déposé
hal-00553168 , version 1 (06-01-2011)
Matthieu Geist, Olivier Pietquin. Statistically Linearized Recursive Least Squares. MLSP 2010, Aug 2010, Kittilä, Finland. pp.272-276, ⟨10.1109/MLSP.2010.5589236⟩. ⟨hal-00553168⟩
28 Consultations
0 Téléchargements
