Systematic Correct Construction of Self-stabilizing Systems: A Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ananda Basu
  • Fonction : Auteur
  • PersonId : 857857
Borzoo Bonakdarpour
  • Fonction : Auteur
Marius Bozga
Joseph Sifakis
  • Fonction : Auteur
  • PersonId : 857859
Design and implementation of distributed algorithms often involve many subtleties due to their complex structure, non-determinism, and low atomicity as well as occurrence of unanticipated physical events such as faults. Thus, constructing correct distributed systems has always been a challenge and often subject to serious errors. We present a methodology for component-based modeling, verification, and performance evaluation of self-stabilizing systems based on the BIP framework. In BIP, a system is modeled as the composition of a set of atomic components by using two types of operators: interactions describing synchronization constraints between components, and priorities to specify scheduling constraints. The methodology involves three steps illustrated using the \dr algorithm due to Arora and Gouda. First, a high-level model of the algorithm is built in BIP from the set of its processes by using powerful primitives for multi-party interactions and scheduling. Then, we use this model for verification of properties of a self-stabilizing algorithm including closure, deadlock-freedom, and finite reachability of the set of legitimate states. Finally, a distributed model which is observationally equivalent to the high-level model is generated. This model is used for performance analysis taking into account the degree of parallelism and convergence times for failure-free behavior as well as in the presence of faults.
main.pdf (477.28 Ko) Télécharger le fichier
hal-00558054 , version 1 (20-01-2011)
Ananda Basu, Borzoo Bonakdarpour, Marius Bozga, Joseph Sifakis. Systematic Correct Construction of Self-stabilizing Systems: A Case Study. Stabilization, Safety, and Security of Distributed Systems - 12th International Symposium, SSS 2010, Sep 2010, New York, NY, United States. pp.4-18, ⟨10.1007/978-3-642-16023-3_4⟩. ⟨hal-00558054⟩
210 Consultations
76 Téléchargements
