Responding to traffic surges: Stochastic networks under time-space-priority scalings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
In multi-class communication networks, traffic surges due to one class of users can significantly degrade the performance for other classes. During these transient periods, it is thus of crucial importance to implement priority mechanisms that conserve the quality of service experienced by the affected classes, while ensuring that the temporarily unstable class is not entirely neglected. In this paper, we examine -- for a suitably-scaled set of parameters -- the complex interaction occurring between several classes of traffic when an unstable class is penalized proportionally to its level of congestion. We characterize the evolution of the performance measures of the network from the moment the initial surge takes place until the system reaches its equilibrium. Using a time-space-transition-scaling, we show that the trajectories of the temporarily unstable class can be described by a differential equation, while those of the stable classes retain their stochastic nature. In particular, we show that the temporarily unstable class evolves at a time-scale which is much slower than that of the stable classes. Although the time-scales decouple, the dynamics of the temporarily unstable and the stable classes continue to influence one another. We further proceed to characterize the obtained differential equations for several simple network examples. In particular, the macroscopic asymptotic behavior of the unstable class allows us to gain important qualitative insights on how the bandwidth allocation affects performance. We illustrate these result on several toy examples and we finally build a penalization rule using these results for a network integrating streaming and elastic traffic.
hal-00559494 , version 1 (25-01-2011)
Matthieu Feuillet, Matthieu Jonckheere, Balakrishna Prabhu. Responding to traffic surges: Stochastic networks under time-space-priority scalings. 2011. ⟨hal-00559494⟩
157 Consultations
0 Téléchargements
