Model-based Clustering of Time Series in Group-specific Functional Subspaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
This work develops a general procedure for clustering functional data which adapts the efficient clustering method HDDC, originally proposed in the multivariate context. The resulting clustering method, called funHDDC, is based on a functional latent mixture model which fits the functional data in group-specific functional subspaces. By constraining model parameters within and between groups, a family of parsimonious models is exhibited which allow to fit onto various situations. An estimation procedure based on the EM algorithm is proposed for estimating both the model parameters and the group-specific functional subspaces. Experiments on real-world datasets show that the proposed approach performs better or similarly than classical clustering methods while providing useful interpretations of the groups.
FunHDDC-HAL.pdf (343.26 Ko) Télécharger le fichier
hal-00559561 , version 1 (25-01-2011)
hal-00559561 , version 2 (31-08-2011)
  • HAL Id : hal-00559561 , version 1
Charles Bouveyron, Julien Jacques. Model-based Clustering of Time Series in Group-specific Functional Subspaces. 2011. ⟨hal-00559561v1⟩
532 Consultations
1912 Téléchargements
