Phase Resetting Control Based On Direct Phase Response Curve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Denis Efimov
The problem of phase resetting control synthesis for nonlinear oscillating systems is considered. The direct phase response curve (PRC) approach is developed and non-local PRC model is used for controls design. Conditions of the model validity and accuracy are determined. Performance of the obtained solution is demonstrated via computer simulation for a heart muscle contraction model.
Fichier non déposé
hal-00560990 , version 1 (31-01-2011)
  • HAL Id : hal-00560990 , version 1
Denis Efimov, Tarek Raissi. Phase Resetting Control Based On Direct Phase Response Curve. IFAC Symposium on Nonlinear Control Systems, Sep 2010, Bologna, Italy. pp.332−337. ⟨hal-00560990⟩
56 Consultations
0 Téléchargements
