Handling Left-Quadratic Rules When Completing Tree Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper addresses the following general problem of tree regular model-checking: decide whether the intersection of R*(L) and Lp is empty, where R* is the reflexive and transitive closure of a successor relation induced by a term rewriting system R, and L and Lp are both regular tree languages. We develop an automatic approximation-based technique to handle this -- undecidable in general -- problem in the case when term rewriting system rules are left-quadratic. The most common practical case is handled this way.
bchk08b_ip.pdf (224.76 Ko) Télécharger le fichier
hal-00563293 , version 1 (04-02-2011)
Yohan Boichut, Roméo Courbis, Pierre-Cyrille Héam, Olga Kouchnarenko. Handling Left-Quadratic Rules When Completing Tree Automata. 2nd Workshop on Reachability Problems in Computational Models - RP'08, Sep 2008, Liverpool, United Kingdom. pp.61--70, ⟨10.1016/j.entcs.2008.12.031⟩. ⟨hal-00563293⟩
162 Consultations
71 Téléchargements
