Pareto Local Optima of Multiobjective NK-Landscapes with Correlated Objectives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we conduct a fitness landscape analysis for multiobjective combinatorial optimization, based on the local optima of multiobjective NK-landscapes with objective correlation. In single-objective optimization, it has become clear that local optima have a strong impact on the performance of metaheuristics. Here, we propose an extension to the multiobjective case, based on the Pareto dominance. We study the co-influence of the problem dimension, the degree of non-linearity, the number of objectives and the correlation degree between objective functions on the number of Pareto local optima.
verel.pdf (161.7 Ko) Télécharger le fichier
hal-00563460 , version 1 (18-07-2012)
Sébastien Verel, Arnaud Liefooghe, Laetitia Jourdan, Clarisse Dhaenens. Pareto Local Optima of Multiobjective NK-Landscapes with Correlated Objectives. 11th European Conference on Evolutionary Computation in Combinatorial Optimisation, Apr 2011, Turino, Italy. pp.226--237. ⟨hal-00563460⟩
435 Consultations
309 Téléchargements
