A Study of Neutrality of Boolean Function Landscapes in Genetic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2012
Neutrality of genetic programming Boolean function landscapes is investigated in this paper. Compared with some well known contributions on the same issue, we define new measures that help characterizing neutral landscapes, we use a new sampling methodology, which captures features that are disregarded by uniform random sampling, we introduce new genetic operators to define the neighborhood of tree structures and we compare the fitness landscape induced by different sets of functional operators. This study indicates the existence of a relationship between our neutrality measures and the performance of genetic programming for the problems studied.
vpm_neutr.pdf (20.52 Mo) Télécharger le fichier
hal-00563462 , version 1 (09-09-2021)
Leonardo Vanneschi, Yuri Pirola, Giancarlo Mauri, Philippe Collard, Sébastien Verel. A Study of Neutrality of Boolean Function Landscapes in Genetic Programming. Theoretical Computer Science, 2012, 425, pp.34 -- 57. ⟨10.1016/j.tcs.2011.03.011⟩. ⟨hal-00563462⟩
245 Consultations
11 Téléchargements
