Multiple Tree for Partially Observable Monte-Carlo Tree Search - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We propose an algorithm for computing approximate Nash equilibria of partially observable games using Monte-Carlo tree search based on recent bandit methods. We obtain experimental results for the game of phantom tic-tac-toe, showing that strong strategies can be effi- ciently computed by our algorithm.
auger_MultipleTree.pdf (151.58 Ko) Télécharger le fichier
hal-00563480 , version 1 (05-02-2011)
hal-00563480 , version 2 (08-02-2011)
  • HAL Id : hal-00563480 , version 1
David Auger. Multiple Tree for Partially Observable Monte-Carlo Tree Search. 2011. ⟨hal-00563480v1⟩
291 Consultations
866 Téléchargements
