Itakura-Saito nonnegative matrix factorization with group sparsity - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
We propose an unsupervised inference procedure for audio source separation. Components in nonnegative matrix factorization (NMF) are grouped automatically in audio sources via a penalized maximum likelihood approach. The penalty term we introduce favors sparsity at the group level, and is motivated by the assumption that the local amplitude of the sources are independent. Our algorithm extends multiplicative updates for NMF; moreover we propose a test statistic to tune hyperparameters in our model, and illustrate its adequacy on synthetic data. Results on real audio tracks show that our sparsity prior allows to identify audio sources without knowledge on their spectral properties.
lefevre_icassp2011.pdf (106.16 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-00567344 , version 1 (20-02-2011)
Identifiers
  • HAL Id : hal-00567344 , version 1
Cite
Augustin Lefevre, Francis Bach, Cédric Févotte. Itakura-Saito nonnegative matrix factorization with group sparsity. 36th International Conference on Acoustics, Speech, and Signal Processing (ICASSP), May 2011, Prague, Czech Republic. ⟨hal-00567344⟩
480 View
2101 Download
Share
