Fully Discrete Control Scheme of the Energy-Performance Tradeoff in Embedded Electronic Devices - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
Sylvain Durand
  • Function : Author
  • PersonId : 858779
A voltage scalable device is known to be interesting for energy saving. It enables to reduce the general speed of the device and, therefore, its consumption. We already proposed a fast predictive control strategy to deal with this power-performance tradeoff in an electronic device supplied by two voltage levels and a continuously varying frequency. In this paper, the approach is extended to a fully discrete scheme with M possible voltage levels and N frequency levels. The proposed approach clearly gives an important reduction of the energy consumption with a very low control computational cost. Moreover, the control strategy is highly robust to tackle variability since it is not based on any parameters of the system.
1961.pdf (208.71 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-00568103 , version 1 (19-03-2015)
Identifiers
Cite
Sylvain Durand, Nicolas Marchand. Fully Discrete Control Scheme of the Energy-Performance Tradeoff in Embedded Electronic Devices. IFAC WC 2011 - 18th IFAC World Congress, Aug 2011, Milan, Italy. ⟨10.3182/20110828-6-IT-1002.01961⟩. ⟨hal-00568103⟩
350 View
146 Download
Share
