Solovay functions and K-triviality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As part of his groundbreaking work on algorithmic randomness, Solovay demonstrated in the 1970s the remarkable fact that there are computable upper bounds of prefix-free Kolmogorov complexity $K$ that are tight on infinitely many values (up to an additive constant). Such computable upper bounds are called Solovay functions. Recent work of Bienvenu and Downey~[STACS 2009, LIPIcs 3, pp 147-158] indicates that Solovay functions are deeply connected with central concepts of algorithmic randomness such as $\Omega$ numbers, K-triviality, and Martin-L\"{o}f randomess. In what follows, among other results we answer two open problems posed by Bienvenu and Downey about the definition of $K$-triviality and about the Gács-Miller-Yu characterization of Martin-L\"{o}f randomess. The former defines a sequence~$A$ to be K-trivial if $K(A\uhr n) \lep K(n)$, the latter asserts that a sequence~$A$ is Martin-L\"{o}f random iff $C(A\uhr n) \gep n-K(n)$. So both involve the noncomputable function $K$. As our main results we show that in both cases $K(n)$ can be equivalently replaced by any Solovay function, and, what is more, that among all computable functions such a replacement is possible exactly for the Solovay functions. Moreover, similar statements hold for the larger class of all right-c.e.\ in place of the computable functions. These full characterizations, besides having significant theoretical interest on their own, will be useful as tools when working with K-trivial and Martin-L\"{o}f random sequences.
42.pdf (238.13 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-00573598 , version 1 (04-03-2011)
  • HAL Id : hal-00573598 , version 1
Laurent Bienvenu, Wolfgang Merkle, André Nies. Solovay functions and K-triviality. Symposium on Theoretical Aspects of Computer Science (STACS2011), Mar 2011, Dortmund, Germany. pp.452-463. ⟨hal-00573598⟩
208 Consultations
148 Téléchargements
