Stability Criteria for Asynchronous Sampled-data Systems - A Fragmentation Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The stability analysis of asynchronous sampled-data systems is studied. The approach is based on a recent result which allows to study, in an equivalent way, the quadratic stability of asynchronous sampled-data systems in a continuous-time framework via the use of peculiar functionals satisfying a necessary boundary condition. The method developed here is an extension of previous results using a fragmentation technique inspired from recent advances in time-delay systems theory. The approach leads to a tractable convex feasibility problem involving a small number of finite dimensional LMIs. The approach is then finally illustrated through several examples.
Partition_IFAC_final.pdf (141.54 Ko) Télécharger le fichier
hal-00575532 , version 1 (10-03-2011)
  • HAL Id : hal-00575532 , version 1
Corentin Briat, Alexandre Seuret. Stability Criteria for Asynchronous Sampled-data Systems - A Fragmentation Approach. IFAC WC 2011 - 18th IFAC World Congress, Aug 2011, Milan, Italy. pp.6. ⟨hal-00575532⟩
290 Consultations
331 Téléchargements
