State Estimation based on the Concept of Continuous Symmetry and Observability Analysis: The Case of Calibration
This paper considers the problem of state estimation in autonomous navigation from a theoretical perspective. In particular, the investigation regards problems where the information provided by the sensor data is not sufficient to carry out the state estimation (i.e. the state is not observable). For these systems, the concept of continuous symmetry is introduced. Detecting the continuous symmetries of a given system has a very practical importance. It allows us to detect an observable state whose components are non linear functions of the original non observable state. So far this theoretical and very general concept has been applied to deal with two distinct fundamental estimation problems in the framework of mobile robotics. The former is in the framework of self-calibration and the latter is in the framework of the fusion of the data provided by inertial sensors and vision sensors. For reasons of length, only the former is discussed. In particular, the theoretical machinery is used to address a specific calibration problem. The solution constrains the robot to move along specific trajectories in order to be able to apply the calibration algorithm. This paper provides two distinct contributions. The first is the introduction of this concept of continuous symmetry. The second is the introduction of a simple and efficient strategy to extrinsically calibrate a bearing sensor (e.g. a vision sensor) mounted on a vehicle and, simultaneously estimate the parameters describing the systematic error of its odometry system. Many accurate simulations and real experiments show the robustness, the efficiency and the accuracy of the proposed strategy.
