A new mathematical model for car drivers with spatial preview - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Sename
Jonathan Dumon
A mathematical driver model is given in the spacial equation form, which takes into account the previewed information of the path. Optimal control method is considered for the ideal no time-delay case and Lyapunov-Krasovskii functional approach is applied to deal with drivers' reaction time-delay. For both cases, exponential stability is guaranteed for the closed loop system.
Mots clés
modelconducteur.pdf (705.05 Ko) Télécharger le fichier
hal-00581800 , version 1 (31-03-2011)
  • HAL Id : hal-00581800 , version 1
Wenjuan Jiang, Carlos Canudas de Wit, Olivier Sename, Jonathan Dumon. A new mathematical model for car drivers with spatial preview. IFAC WC 2011 - 18th IFAC World Congress, Aug 2011, Milan, Italy. pp.10206. ⟨hal-00581800⟩
217 Consultations
1189 Téléchargements
