Expressing Adaptation Strategies using Adaptation Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Learning Technologies Année : 2012
Today, there is a real challenge to enable personalized access to information. Several systems have been proposed to address this challenge including Adaptive Hypermedia Systems (AHSs). How- ever, the specification of adaptation strategies remains a difficult task for creators of such systems. In this paper, we consider the problem of the definition of adaptation strategies at a high level. We present two main contributions: a typology of elementary adaptation patterns for the adaptive navigation; and a process to generate adaptation strategies based on the use and the semi-automatic combination of patterns. We also describe how the generated adaptation strategies can be integrated into existing AHSs. A prototype has been implemented and an experiment in the e-learning domain has been conducted with a group of volunteers. This experiment shows that our pattern based approach for defining adaptation strategies is more suitable than those based on "traditional" AH languages.
hal-00583450 , version 1 (05-04-2011)
Nadjet Zemirline, Yolaine Bourda, Chantal Reynaud. Expressing Adaptation Strategies using Adaptation Patterns. IEEE Transactions on Learning Technologies, 2012, 5 (1), pp.38-51. ⟨10.1109/TLT.2011.15⟩. ⟨hal-00583450⟩
104 Consultations
0 Téléchargements
