Aspect-Oriented Model Development at Different Levels of Abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The last decade has seen the development of many diverse aspect-oriented modeling (AOM) approaches. This paper presents eight different AOM approaches that produce models at different level of ab- straction. The approaches are different with respect to the phases of the development lifecycle they target, and the support they provide for model composition and verification. The approaches are illustrated by models of the same concern from a case study to enable comparing of their expressive means. Understanding common elements and differences of approaches clarifies the role of aspect-orientation in the software de- velopment process.
ecmfa2011_bellairs.pdf (1.05 Mo) Télécharger le fichier
hal-00585301 , version 1 (12-04-2011)
hal-00585301 , version 2 (28-07-2011)
  • HAL Id : hal-00585301 , version 1
Mauricio Alférez, Nuno Amalio, Selim Ciraci, Franck Fleurey, Jörg Kienzle, et al.. Aspect-Oriented Model Development at Different Levels of Abstraction. Seventh European Conference on Modelling Foundations and Applications(ECMFA'11), long paper, Jun 2011, Birmingham, UK, France. pp.1-16. ⟨hal-00585301v1⟩
372 Consultations
469 Téléchargements
