Multinomial model-based formulations of TCP and NTCP for radiotherapy treatment planning - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Journal of Theoretical Biology Year : 2011
Hit and target models of tumor growth, typically assume that all surviving cells have a constant and homogeneous sensitivity during the radiotherapy period. In this study, we propose a new multinomial model based on a discrete-time Markov chain, able to take into account cell repair, cell damage heterogeneity and cell proliferation. The proposed model relies on the 'Hit paradigm' and 'Target' theory in radiobiology and assumes that a cancer cell contains m targets which must be all deactivated to produce cell death. The surviving cell population is then split up into m categories to introduce the variation of cancer cell radio-sensitivity according to their damage states. New expressions of the tumor control probability (TCP) and normal tissue complication probability (NTCP) are provided. Moreover, we show that hit and target models may be regarded as particular cases of the multinomial model. Numerical results should permit to keep the efficiency of treatment with a lower total radiation dose then that given by the typical hit models, which allows to decrease side effects.
JTB-2010.pdf (328.2 Ko) Télécharger le fichier
Dates and versions
hal-00588935 , version 1 (27-04-2011)
Identifiers
Cite
Roukaya Keinj, Thierry Bastogne, Pierre Vallois. Multinomial model-based formulations of TCP and NTCP for radiotherapy treatment planning. Journal of Theoretical Biology, 2011, 279 (1), pp.55-62. ⟨10.1016/j.jtbi.2011.03.025⟩. ⟨hal-00588935⟩
356 View
820 Download
Share
