Event in Compositional Dynamic Semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sai Qian
  • Fonction : Auteur
  • PersonId : 764456
  • IdRef : 182066258
Maxime Amblard
We present a framework which constructs an event-style dis- course semantics. The discourse dynamics are encoded in continuation semantics and various rhetorical relations are embedded in the resulting interpretation of the framework. We assume discourse and sentence are distinct semantic objects, that play different roles in meaning evalua- tion. Moreover, two sets of composition functions, for handling different discourse relations, are introduced. The paper first gives the necessary background and motivation for event and dynamic semantics, then the framework with detailed examples will be introduced.
Event_in_Compositional_Dynamic_Semantics1.pdf (183.84 Ko) Télécharger le fichier
Event_in_Compositional_Dynamic_Semantics.pdf (558.31 Ko) Télécharger le fichier
Format : Autre
hal-00601620 , version 1 (24-08-2011)
Sai Qian, Maxime Amblard. Event in Compositional Dynamic Semantics. 6th International Conference on Logical Aspect of Computational Linguistic - LACL 2011, Jun 2011, Montpellier, France. pp.219--234, ⟨10.1007/978-3-642-22221-4_15⟩. ⟨hal-00601620⟩
181 Consultations
723 Téléchargements
