Non shape regular domain decompositions: an analysis using a stable decomposition in $H_0^1$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we establish the existence of a stable decomposition in the Sobolev space $H^1_0$ for domain decompositions which are not shape regular in the usual sense. In particular, we consider domain decompositions where the largest subdomain is significantly larger than the smallest subdomain. We provide an explicit upper bound for the stable decomposition that is independant of the ratio between the diameter of the largest and the smallest subdomain.
NonShapeRegularStableDecompositionv2.pdf (143.86 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00607043 , version 1 (07-07-2011)
hal-00607043 , version 2 (10-02-2012)
Martin J. Gander, Laurence Halpern, Kévin Santugini-Repiquet. Non shape regular domain decompositions: an analysis using a stable decomposition in $H_0^1$. 20th International Conference on Domain Decomposition Methods, Feb 2011, La Jolla, United States. pp.485--492, ⟨10.1007/978-3-642-35275-1_57⟩. ⟨hal-00607043v2⟩
315 Consultations
337 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
