Functional kernel estimators of large conditional quantiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Statistics Année : 2012
We address the estimation of conditional quantiles when the covariate is functional and when the order of the quantiles converges to one as the sample size increases. In a first time, we investigate to what extent these large conditional quantiles can still be estimated through a functional kernel estimator of the conditional survival function. Sufficient conditions on the rate of convergence of their order to one are provided to obtain asymptotically Gaussian distributed estimators. In a second time, basing on these result, a functional Weissman estimator is derived, permitting to estimate large conditional quantiles of arbitrary large order. These results are illustrated on finite sample situations.
qdafonclis6.pdf (304.02 Ko) Télécharger le fichier
hal-00608192 , version 1 (12-07-2011)
hal-00608192 , version 2 (20-01-2012)
hal-00608192 , version 3 (21-08-2012)
hal-00608192 , version 4 (25-04-2013)
Laurent Gardes, Stéphane Girard. Functional kernel estimators of large conditional quantiles. Electronic Journal of Statistics , 2012, 6, pp.1715-1744. ⟨hal-00608192v3⟩
390 Consultations
276 Téléchargements
