Frequency Estimation for Periodical Signal with Noise in Finite Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of parametric estimation of harmonic signals in the presence of noise and computational constraints is an important issue in many engineering fields. The paper proposes an algorithm for frequency and bias estimation under noisy measurements.
Fichier non déposé
hal-00609891 , version 1 (20-07-2011)
  • HAL Id : hal-00609891 , version 1
Anton Pyrkin, Bobstov Alexy, Denis Efimov, Ali Zolghadri. Frequency Estimation for Periodical Signal with Noise in Finite Time. CDC-ECC 2011, Dec 2011, France. pp.XX. ⟨hal-00609891⟩
66 Consultations
0 Téléchargements
