Algebraic Domain Decomposition Methods for Highly Heterogeneous Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2013
We consider the solving of linear systems arising from porous media flow simulations with high heterogeneities. Using a Newton algorithm to handle the non-linearity leads to the solving of a sequence of linear systems with different but similar matrices and right hand sides. The parallel solver is a Schwarz domain decomposition method. The unknowns are partitioned with a criterion based on the entries of the input matrix. This leads to substantial gains compared to a partition based only on the adjacency graph of the matrix. From the information generated during the solving of the first linear system, it is possible to build a coarse space for a two-level domain decomposition algorithm that leads to an acceleration of the convergence of the subsequent linear systems. We compare two coarse spaces: a classical approach and a new one adapted to parallel implementation.
paper.pdf (1.43 Mo) Télécharger le fichier
hal-00611997 , version 1 (27-07-2011)
hal-00611997 , version 2 (19-02-2013)
  • HAL Id : hal-00611997 , version 2
Pascal Have, Roland Masson, Frédéric Nataf, Mikolaj Szydlarski, Hua Xiang, et al.. Algebraic Domain Decomposition Methods for Highly Heterogeneous Problems. SIAM Journal on Scientific Computing, 2013, 35 (3), pp.C284-C302. ⟨hal-00611997v2⟩
799 Consultations
870 Téléchargements
