Algebraic Domain Decomposition Methods for Highly Heterogeneous Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Pascal Have
  • Fonction : Auteur
  • PersonId : 878615
Roland Masson
Frédéric Nataf
Tao Zhao
  • Fonction : Auteur
  • PersonId : 906453
We consider the solving of linear systems arising from porous media flow simulations with high heterogeneities. Using a Newton algorithm to handle the non-linearity leads to the solving of a sequence of linear systems with different but similar matrices and right hand sides. The parallel solver is a Schwarz domain decomposition method. The unknowns are partitioned with a criterion based on the entries of the input matrix. This leads to substantial gains compared to a partition based only on the adjacency graph of the matrix. From the information generated during the solving of the first linear system, it is possible to build a coarse space for a two-level domain decomposition algorithm that leads to an acceleration of the convergence of the subsequent linear systems. We compare two coarse spaces: a classical approach and a new one adapted to parallel implementation.
paper.pdf (1.45 Mo) Télécharger le fichier
hal-00611997 , version 1 (27-07-2011)
hal-00611997 , version 2 (19-02-2013)
  • HAL Id : hal-00611997 , version 1
Pascal Have, Roland Masson, Frédéric Nataf, Mikolaj Szydlarski, Tao Zhao. Algebraic Domain Decomposition Methods for Highly Heterogeneous Problems. 2011. ⟨hal-00611997v1⟩
800 Consultations
878 Téléchargements
