Trace Lasso: a trace norm regularization for correlated designs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Using the $\ell_1$-norm to regularize the estimation of the parameter vector of a linear model leads to an unstable estimator when covariates are highly correlated. In this paper, we introduce a new penalty function which takes into account the correlation of the design matrix to stabilize the estimation. This norm, called the trace Lasso, uses the trace norm, which is a convex surrogate of the rank, of the selected covariates as the criterion of model complexity. We analyze the properties of our norm, describe an optimization algorithm based on reweighted least-squares, and illustrate the behavior of this norm on synthetic data, showing that it is more adapted to strong correlations than competing methods such as the elastic net.
articletl.pdf (280.94 Ko) Télécharger le fichier
hal-00620197 , version 1 (09-09-2011)
Edouard Grave, Guillaume Obozinski, Francis Bach. Trace Lasso: a trace norm regularization for correlated designs. Neural Information Processing Systems (NIPS), 2012, Spain. ⟨hal-00620197⟩
3562 Consultations
681 Téléchargements
