A Two-Level Model of Anticipation-Based Motor Learning for Whole Body Motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
We present a model of motor learning based on a combination of Operational Space Control and Optimal Control. Anticipatory processes are used both in the learning of the dynamics model of the system and in the coordination between both types of control. In order to illustrate the proposed model and associated control method, we apply these principles to the control of a simplified virtual humanoid performing a stand-up task starting from a crouching posture.
2009COS1468.pdf (670.7 Ko) Télécharger le fichier
hal-00624103 , version 1 (15-09-2011)
Camille Salaün, Vincent Padois, Olivier Sigaud. A Two-Level Model of Anticipation-Based Motor Learning for Whole Body Motion. Giovanni Pezzulo, Martin V. Butz, Olivier Sigaud and Gianluca Baldassarre. Anticipatory Behavior in Adaptive Learning Systems: From Psychological Theories to Artificial Cognitive System, Springer, pp.229--246, 2009, Lecture Notes in Computer Science Volume 5499, ⟨10.1007/978-3-642-02565-5_13⟩. ⟨hal-00624103⟩
215 Consultations
318 Téléchargements
