A Tight Bound on the Set Chromatic Number - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discussiones Mathematicae Graph Theory Année : 2013
The purpose of this note is to provide a tight bound on the set chromatic number of a graph in terms of its chromatic number. Namely, for all graphs G, we show that χs(G) ≥ log2χ(G) + 1, where χs(G) and χ(G) are the set chromatic number and the chromatic number of G, respectively. This answers in the affirmative a conjecture of Gera, Okamoto, Rasmussen and Zhang.
SeYi11.pdf (329.38 Ko) Télécharger le fichier
hal-00624323 , version 1 (16-09-2011)
hal-00624323 , version 2 (04-12-2013)
Jean-Sébastien Sereni, Zelealem Yilma. A Tight Bound on the Set Chromatic Number. Discussiones Mathematicae Graph Theory, 2013, 33 (2), pp.461--465. ⟨10.7151/dmgt.1679⟩. ⟨hal-00624323v2⟩
165 Consultations
335 Téléchargements
