Supplement to "Robust linear least squares regression" - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Statistics Année : 2011
This supplementary material provides the proofs of Theorems 2.1, 2.2 and 3.1 of the article ''Robust linear least squares regression''.
AOS918_supp.pdf (175.93 Ko) Télécharger le fichier
hal-00624459 , version 1 (17-09-2011)
Jean-Yves Audibert, Olivier Catoni. Supplement to "Robust linear least squares regression". Annals of Statistics, 2011, 39 (5), 19 p. ⟨10.1214/11-AOS918SUPP⟩. ⟨hal-00624459⟩
627 Consultations
237 Téléchargements
