Semantic hierarchies for image annotation: A survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2012
In this survey, we argue that using structured vocabularies is capital to the success of image annotation. We analyze literature on image annotation uses and user needs, and we stress the need for automatic annotation. We briefly expose the difficulties posed to machines for this task and how it relates to controlled vocabularies. We survey contributions in the field showing how structures are introduced. First we present studies that use unstructured vocabulary, focusing on those introducing links between categories or between features. Then we review work using structured vocabularies as an input and we analyze how the structure is exploited.
hal-00624460 , version 1 (17-09-2011)
Anne-Marie Tousch, Stéphane Herbin, Jean-Yves Audibert. Semantic hierarchies for image annotation: A survey. Pattern Recognition, 2012, 45 (1), pp.333-345. ⟨10.1016/j.patcog.2011.05.017⟩. ⟨hal-00624460⟩
434 Consultations
0 Téléchargements
