A typology of adaptation patterns for expressing adaptive navigation in Adaptive Hypermedia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Over the last decade, Adaptive hypermedia (AH) have been under development [8], and particularly in education [3], [9], where learners have access to personalized resources1 according to their knowledge, preferences and goals. In this paper, we present only the the typology of our elementary adaptation patterns, while the whole process of defining adaptation strategies for the adaptive navigation is described in [10]. The paper is organized as follows. In section 2, we define the notion of elementary adaptation patterns that we propose. Afterwhat, in section 3 we present the syntax of the elementary adaptation patterns and followed in section 4 by the description of the associated semantic. In section 5, we detail the typology of the elementary adaptation patterns. Finally, in section 6 we conclude the paper.
RR1541.pdf (407.14 Ko) Télécharger le fichier
hal-00627457 , version 1 (04-10-2011)
  • HAL Id : hal-00627457 , version 1
Nadjet Zemirline, Yolaine Bourda, Chantal Reynaud. A typology of adaptation patterns for expressing adaptive navigation in Adaptive Hypermedia. [Research Report] Supélec. 2011. ⟨hal-00627457⟩
318 Consultations
139 Téléchargements
