Sur le calcul numérique des modes non linéaires - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
This paper deals with non linear normal modes (NNM) computation. The partial differential equations (PDE) governing the geometry of the NNM in phase space is solved via a finite difference scheme. The PDE is integrated as a transport equation, the initial conditions of which are searched so as to result in periodic solutions. The solving and optimisation algorithms are tested on a 2 dof system with cubic non-linearities. This example let us discuss the algorithms' convergence and implementation. The results are also compared to computations with more standard continuation methods.
ModesNL-CFM2011Corrige.pdf (472.41 Ko) Télécharger le fichier
Dates and versions
hal-00627519 , version 1 (28-09-2011)
Identifiers
  • HAL Id : hal-00627519 , version 1
Cite
François Blanc, Kerem Ege, Cyril Touzé, Jean-François Mercier, Anne-Sophie Bonnet-Ben Dhia. Sur le calcul numérique des modes non linéaires. CFM 20111 - 20ième Congrès Français de Mécanique, Aug 2011, Besançon, France. pp.1-6. ⟨hal-00627519⟩
322 View
230 Download
Share
