SWASHES: a library of Shallow Water Analytic Solutions for Hydraulic and Environmental Studies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
A significant number of analytic solutions to the Shallow Water equations is discribed in a unified formalism. They encompass a wide variety of flow conditions (supercritical, subcritical, shock, etc.), in 1 or 2 space dimensions, with or without rain and soil friction, for transitory flow or steady state. An original feature is that the corresponding source codes are made available to the community (http://www.univ-orleans.fr/mapmo/soft/SWASHES), so that users of Shallow Water based models can easily find an adaptable benchmark library to validate numerical methods.
SWASHES.pdf (461.85 Ko) Télécharger le fichier
hal-00628246 , version 1 (30-09-2011)
hal-00628246 , version 2 (04-05-2012)
hal-00628246 , version 3 (25-09-2013)
hal-00628246 , version 4 (04-12-2013)
hal-00628246 , version 5 (10-02-2014)
hal-00628246 , version 6 (19-01-2016)
Olivier Delestre, Carine Lucas, Pierre-Antoine Ksinant, Frédéric Darboux, Christian Laguerre, et al.. SWASHES: a library of Shallow Water Analytic Solutions for Hydraulic and Environmental Studies. 2011. ⟨hal-00628246v1⟩
2396 Consultations
4166 Téléchargements
