Funclust: a curves clustering method using functional random variables density approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurocomputing Année : 2013
Julien Jacques
Cristian Preda
  • Fonction : Auteur
  • PersonId : 911328
A new method for clustering functional data is proposed under the name Funclust. This method relies on the approximation of the notion of probability density for functional random variables, which generally does not exists. Using the Karhunen-Loeve expansion of a stochastic process, this approximation leads to define an approximation for the density of functional variables. Based on this density approximation, a parametric mixture model is proposed. The parameter estimation is carried out by an EM-like algorithm, and the maximum a posteriori rule provides the clusters. The efficiency of Funclust is illustrated on several real datasets, as well as for the characterization of the Mars surface.
Paper-Funclust-V2-versionHAL.pdf (440.59 Ko) Télécharger le fichier
hal-00628247 , version 1 (30-09-2011)
hal-00628247 , version 2 (13-10-2012)
Julien Jacques, Cristian Preda. Funclust: a curves clustering method using functional random variables density approximation. Neurocomputing, 2013, 112, pp.164-171. ⟨10.1016/j.neucom.2012.11.042⟩. ⟨hal-00628247v2⟩
818 Consultations
694 Téléchargements
