Model-based clustering of functional data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Model-based clustering for functional data is considered. An alternative to model-based clustering using the functional principal components is proposed by approximating the density of functional random variables. The EM algorithm is used for parameter estimation and the maximum a posteriori rule provides the clusters. Simulation study and real data application illustrate the interest of the proposed methodology.
Model-Based-Fun-Clust-Jacques-Preda.pdf (635.81 Ko) Télécharger le fichier
hal-00628247 , version 1 (30-09-2011)
hal-00628247 , version 2 (13-10-2012)
  • HAL Id : hal-00628247 , version 1
Julien Jacques, Cristian Preda. Model-based clustering of functional data. 2011. ⟨hal-00628247v1⟩
826 Consultations
713 Téléchargements
