Exponential Stabilization of a Class of Nonlinear Neutral Type Time-Delay Systems, an Oilwell Drilling Model Example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with exponential stabilization of the class of nonlinear neutral type time-delay systems that can be transformed into a multi-model system. The approach is based on Lyapunov-Krasovskii techniques and uses a descriptor representation. The exponential stability properties are proved using an appropriate change of variables associated with a polytopic representation. The results are given in terms of LMIs. As an application example, we determine an e ective stabilizing controller for an oilwell drilling system.
CCE2011.pdf (406.97 Ko) Télécharger le fichier
hal-00632606 , version 1 (14-10-2011)
  • HAL Id : hal-00632606 , version 1
Martha Belem Saldivar, Alexandre Seuret, Sabine Mondié. Exponential Stabilization of a Class of Nonlinear Neutral Type Time-Delay Systems, an Oilwell Drilling Model Example. CCE 2011 - 8th International Conference on Electrical Engineering, Computing Science and Automatic Control, Oct 2011, Mérida City, Yucatan, Mexico. pp.n.c. ⟨hal-00632606⟩
497 Consultations
285 Téléchargements
