Space-time planning in dynamic environments with unknown evolution. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Numerous path planning solutions have been proposed to solve the navigation problem in static environments, potentially populated with dynamic obstacles. However, in dynamic environments, moving objects can be used to reach new locations. In this paper, we propose an online planning algorithm for dynamically changing environments with unknown evolution. This method focuses on accessibility and on the use of objects movements to reach a given target. Among other examples, we will show that this algorithm is able to find a path through moving platforms to reach a target located on a surface that is never directly accessible. We will also show that the proposed representation enables several kind of adaptations such as avoiding moving obstacles or adapting the character postures to environmental constraints.
Fichier non déposé
hal-00639664 , version 1 (09-11-2011)
  • HAL Id : hal-00639664 , version 1
Thomas Lopez, Fabrice Lamarche, Tsai-Yen Li. Space-time planning in dynamic environments with unknown evolution.. Motion In Games, Nov 2011, Edimbourg, United Kingdom. ⟨hal-00639664⟩
258 Consultations
0 Téléchargements
