Deformable Random Dot Markers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We extend planar fiducial markers using random dots 8 to non- rigidly deformable markers. Because the recognition and tracking of random dot markers are based on keypoint matching, we can estimate the deformation of the markers with nonrigid surface de- tection from keypoint correspondences. First, the initial pose of the markers is computed from a homography with RANSAC as a planar detection. Second, deformations are estimated from the min- imization of a cost function for deformable surface fitting. We show augmentation results of 2D surface deformation recovery with sev- eral markers.
Mots clés
2011_ismar_uchiyama-2.pdf (437.87 Ko) Télécharger le fichier
hal-00639703 , version 1 (09-11-2011)
  • HAL Id : hal-00639703 , version 1
H. Uchiyama, E. Marchand. Deformable Random Dot Markers. IEEE Int. Symp. on Mixed and Augmented Reality, ISMAR'11, 2011, Basel, Switzeland, Switzerland. pp.237-238. ⟨hal-00639703⟩
288 Consultations
474 Téléchargements
