Checking NFA equivalence with bisimulations up to congruence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce bisimulation up to congruence as a technique for proving language equivalence of non-deterministic finite automata. Exploiting this technique, we devise an optimisation of the classical algorithm by Hopcroft and Karp. We compare our algorithm to the recently introduced antichain algorithms, by analysing and relating the two underlying coinductive proof methods. We give concrete examples where we exponentially improve over antichains; experimental results moreover show non negligible improvements on random automata.
hkc.pdf (389.86 Ko) Télécharger le fichier
hal-00639716 , version 1 (09-11-2011)
hal-00639716 , version 2 (06-12-2011)
hal-00639716 , version 3 (14-01-2012)
hal-00639716 , version 4 (27-02-2012)
hal-00639716 , version 5 (11-07-2012)
Filippo Bonchi, Damien Pous. Checking NFA equivalence with bisimulations up to congruence. Principle of Programming Languages (POPL), Jan 2013, Roma, Italy. pp.457-468, ⟨10.1145/2429069.2429124⟩. ⟨hal-00639716v5⟩
768 Consultations
5967 Téléchargements
