Hopcroft and Karp's algorithm for Non-deterministic Finite Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2011
Damien Pous
Connectez-vous pour contacter l'auteur
An algorithm is given for determining if two non-deterministic finite automata are language equivalent. We exploit up-to techniques to improve the standard algorithm by Hopcroft and Karp for deterministic finite automata, so as to avoid computing the whole deterministic automata. Although the proposed algorithm remains exponential in worst case (the problem is PSPACE-complete), experimental results show that it can be much faster than the standard algorithm: only a very small portion of the determinized automata have to be explored in practice.
hkc.pdf (393.68 Ko) Télécharger le fichier
hal-00639716 , version 1 (09-11-2011)
hal-00639716 , version 2 (06-12-2011)
hal-00639716 , version 3 (14-01-2012)
hal-00639716 , version 4 (27-02-2012)
hal-00639716 , version 5 (11-07-2012)
  • HAL Id : hal-00639716 , version 2
Filippo Bonchi, Damien Pous. Hopcroft and Karp's algorithm for Non-deterministic Finite Automata. 2011. ⟨hal-00639716v2⟩
776 Consultations
6116 Téléchargements
