A Generalization of the Fourier Transform and its Application to Spectral Analysis of Chirp-like Signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied and Computational Harmonic Analysis Année : 2011
We show that the de Branges theory provides a useful generalization of the Fourier Transform (FT). The formulation is quite rich in that by selecting the appropriate para\-me\-trization, one can obtain spectral representation for a number of important cases. We demonstrate two such cases in this letter: the finite sum of elementary chirp-like signals, and a decaying chirp using Bessel functions. We show that when defined in the framework of de Branges spaces, these cases admit a representation very much similar to the spectral representation of a finite sum of sinusoids for the usual FT.
debranges_chirp_ACHA_HAL.pdf (1.8 Mo) Télécharger le fichier
hal-00640508 , version 1 (12-11-2011)
hal-00640508 , version 2 (22-11-2011)
Mamadou Mboup, Tülay Adali. A Generalization of the Fourier Transform and its Application to Spectral Analysis of Chirp-like Signals. Applied and Computational Harmonic Analysis, 2011, ⟨10.1016/j.acha.2011.11.002⟩. ⟨hal-00640508v1⟩
219 Consultations
750 Téléchargements
