Gas phase appearance and disappearance as a problem with complementarity constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics and Computers in Simulation Année : 2013
The modeling of migration of hydrogen produced by the corrosion of the nuclear waste packages in an underground storage including the dissolution of hydrogen involves a set of nonlinear partial differential equations with nonlinear complementarity constraints. This article shows how to apply a modern and efficient solution strategy, the Newton-min method, to this geoscience problem and investigates its applicability and efficiency. In particular, numerical experiments show that the Newton-min method is quadratically convergent for this problem.
RR-7803.pdf (459.93 Ko) Télécharger le fichier
hal-00641621 , version 1 (16-11-2011)
hal-00641621 , version 2 (08-01-2014)
Ibtihel Ben Gharbia, Jérôme Jaffré. Gas phase appearance and disappearance as a problem with complementarity constraints. Mathematics and Computers in Simulation, 2013. ⟨hal-00641621v1⟩
339 Consultations
215 Téléchargements
