An Integration Framework For Control/Communication/Computation (3C) Co-design With Application In Fleet Control Of AUVs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we introduce an integration framework for Control/Communication/Computation (3C) co-design based on the motivating example of fleet control of Autonomous Underwater Vehicles (AUVs). Specifically, we address the problem of almost sure stability of an unstable system with multiple observations over packet erasure channel with emphasize on coding computational complexity. We look at the tradeoff between duty cycle for feedback channel use, coding computational complexity, and performance. We compare coding computational complexity and performance for two cases: a) No feedback channel at all, and b) Feedback channel all the time. It is shown that the strategy of using feedback channel results in a better performance.
CDC2011-08-25.pdf (254.05 Ko) Télécharger le fichier
hal-00642028 , version 1 (17-11-2011)
  • HAL Id : hal-00642028 , version 1
Alireza Farhadi, Carlos Canudas de Wit. An Integration Framework For Control/Communication/Computation (3C) Co-design With Application In Fleet Control Of AUVs. CDC 2011 - ECC 2011 - 50th IEEE Conference on Decision and Control and European Control Conference, Dec 2011, Orlando, Floride, United States. pp.s/n. ⟨hal-00642028⟩
163 Consultations
238 Téléchargements
