Oscillation annealing and driver/tire load torque estimation in Electric Power Steering Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper presents several aspects of modeling, observation and control towards a new generation of Electrical Power Steering(EPS) systems. In particular we design an optimal control to reject oscillations of the steering column, then we device a new observer to estimate the internal state variables of the steering column, the driver applied torque (steering wheel torque), and the load torque (tire/ground contact friction). Finally, we also revisited the LuGre tire dynamic friction model by improving the transient behavior between the sticking phases and the dynamic ones. Simulation of the proposed control and observer are shown at the end of the paper using the improved LuGre-tire friction model.
EPS_IEEE_MSC2011_last.pdf (337.19 Ko) Télécharger le fichier
hal-00642035 , version 1 (17-11-2011)
  • HAL Id : hal-00642035 , version 1
Javier Tordesillas, Valentina Ciarla, Carlos Canudas de Wit. Oscillation annealing and driver/tire load torque estimation in Electric Power Steering Systems. MSC 2011 - IEEE Multi-Conference on Systems and Control, Sep 2011, Denver, United States. pp.s/n. ⟨hal-00642035⟩
268 Consultations
569 Téléchargements
